hydro clutch question
nerraw117
charlotte, NC
i got my pedals in and they are hydro. i have not bled the system yet, but when i push down the pedal, it does not return all the way up, it does about 90%. when i bleed the system will the pedal be pushed all the way up or did i hook the spring up wrong? i really dont want to drop everything to put in a new spring or whatever. thanks ck5
i dont have a spring that i know of in my setup. i installed all of mine. my pedel comes up 100%.
and do a advanced search with my screen name and the word hydro. you will find a good thread on bleading the clutch from hell.
Yes , there is a spring on a hydro pedal set up.
It is on the located on the clutch pedal pivot bolt ,left hand side between the pedal & the hanger.
It's not very big ,but it's there none the less.
The pedal will return when you get the system bleed correctly.
yea i got the spring in there correctly. just didnt know if it would return when i got it bleed. thanks
What attaches to the round shoulder that the clip is running through? If I read this correctly there is no big spring for pedal return because line pressure returns the pedal.
Yeah, I noticed that too when I did my hydro conversation, where it wouldn’t fully return until it was filled with fluid and bleed. Don’t sweat it, hook it up and enjoy a nice smooth easy clutch to press.
Here is a cool picture of the ’85-’87 (’91 R/V) hydro system. Too neat not to share.
