I did the ORD 3" lift to my m1009.That might be a possibility--If I remember right,on this truck I never could get the brake warning light to shut off even after bleeding it and having excellent brakes,and full flow to the rear wheel cylinders..to pass inspection, you must have the light working,when they turn on the key without starting the engine..so I unplugged the wire on the PV to keep it from staying on once they started it up..still works when you apply the e-brake too..
They "test" your brake lines here by stomping on the brake pedal hard enough to pop new ones too,maybe that messed something up in the hydroboost,but it didn't start feeling like it lost some of the power assist until a few months ago--inspection time was in June..
I'm wondering if the leaking pitman shaft seal might be reducing the pressure to the hydroboost unit..but that didn't start leaking until a few weeks ago too..(and so far its not a "gusher",just drippage)..
Part of the lift was longer front brake lines and a longer rear line.
That rear line was very difficult to purge the air out of.
Vacuum bleeding, pressure bleeding.
It just would not go.
Then i discovered my tripped prop valve.
Took 2 tries to reset the prop valve and get air bled out.
There is a button under a rubber nub on the left side of the valve to reset the front brake failure.. but the rear has nothing.
The most common cure is to stomp on the pedal hard and hope to reset the prop valve.
In my case, no love.
So removal of prop valve and manual reset was neccesary.
You can reach through the hole under the warning switch with a pick tool and reset it too, but i found it near impossible with my big diesel radiator in the way.
