Crank sensors SUCK to replace on many cars...they hide them in stupid places like the bellhousing,in the engine block,etc,and always where access is dam near impossible...I've seen my friend spend the better part of a day trying to remove one that is heat baked into the mounting surface and needed to be drilled or smashed into bits to be removed!...you wouldn't think a hunk of plastic with an o ring could be so difficult to get out,but in aluminum they practically weld in from electrolosis..
Rene..a 4.7 ?...Ewwwwwww.....!..my friend has replaced about ten of those engines in Dodge and Jeeps this year...they are almost as bad as the 2.7 V-6,Mopars worst engine yet..(he put THREE of those in one car before he got a "good" one..first two didn't make it two days,one had an oil pan full of jelly like sludge and the new oil he put in evidently flushed it loose--killed the main bearings in short order..second engine ran sweet,but the water pump,which is INSIDE the engine and driven off the cam belt ,decided to peuke prestone into the crankcase,and out of the "weep tube" that evidently couldn't drain off the leakage fast enough..that one died in 3 days ,started rapping like a woodpecker..its easier to put another engine in than replace the water pump,and the way they built it,once it leaks the engine is junk anyway..
I cant say I'm a big fan of ANY make of car or truck when it comes to piss poor engineering..ALL of them have stupid designs and hidden bolts or things you cant get at,or fail rapidly because THEY aren't the ones who have to FIX them!....I feel the "engineers" should have to be MECHANICS for 10 years before being allowed to design a new vehicle!..things would be a lot different if they had to work on what they design!..
