4xcrazy
3/4 ton status
what was the old engine, 305 or 350? what is the new one.
what was the old emgine, 305 or 350? what is the new one.
aight, was just curious cause i have seen two different balancers before, the one i had a long time ago was in a 305 and the timing mark was read through the top, down between the water pump and the timing cover, not sure if they ever did that on the trucks though. Someone else on here may know that definate answer.
I would say now, charge the battery, if it doesn't start, move the distributor in about 1/2 inch increments or smaller, advancing it alittle at a time, then back it up if it still won't start, and try, don't over crank it though, if it wont start withing a few cranks even with ether, it's not set right. don't over use that ether, either, that's some nasty stuff if you use too much.
Rotor was pointing to where no4 would normally, so you started your no1 wire from there, running them clockwise , 1,3,5,7 down the driver side, 2,4,6,8 down the pass side.
Hmm now i'm confused, I thought I ran it As the firing order. around the Dizzy
Yes you do, i'm talking about the actual cyl numbers now and their locations.
Just wondering as i have broken those clips in the past and just fixed it with a female spade connector. :P
Alright, and you have power going to that wire as well, correct?
Does the engine spit or cough at all through the carb while you're trying to start it?
Yeah I have 12.63 volts to that wire, Itested it before My last crank. so battery was kinda dead. but still 12v. Not that I noticed I dont hear it
Well i,m thinkin now from our extensive discussion, and your descriptions you have given me, it should fire up, i ask about the coughing out the carb as that's usually a good indicator that it's firing, just not at the right time. So now i'm even starting to think something is at fault with the coil pack or something in the dizzy was not hooked up right.
