I was just driving home and I heard a pop and sounded like some rocks in a coffee can. there are some vibrations when i went up the hill of the driveway. Im not sure what happened. but now it makes noise and has a vibration when driving up hill.
Please make sure when you do this that you block both front tires from the front and back. We don't want the truck rolling onto you!right now your shafts are tight, I am assuming your in part. Lift the rear of the truck up where both tires are off the ground. put your shifter in nuetral , then spin your rear driveshaft and see if you get any looseness.
