How much are willing/wanting to lower the vehicle? To eliminate some of the pack, you'll need to take it apart. You could pull a leaf or two and replace it with a "zero rate" leaf/block. Technically you can make that zero rate out of the old leafs, but you want to cut them even shorter, like the length of the spring pad on the axle. That way everything outside of the U-bolts is normal. As said above, you would round off the top edge of the top cut leaf, so it doesn't put extra stress in your new bottom leaf. The only reason to even leave the cut leafs in is to gain that small amount of height from their thickness.
The problem with leaf swapping is you don't really know what you're going to get for height or spring rate until you try it. Getting the stance right may take multiple iterations. The life of the springs is also unknown. But if you have time to kill playing with it, it doesn't cost much more than a set of U-bolts. You may decide to go an entirely different direction with the truck before your franken-springs sag.
Keep your eyes open for some used springs popping up so you know what you're getting. It looks like brand new EZ-rides are about $225/each. Do you have lift springs at all 4 corners?
