Only the temperature gauge/gauges.
Finally got around to welding a bung into the 465's PTO cover, so was able to hook up a temperature sender to it. (Digression: I know it's not needed, just a good proof of concept for future engine oil temp sensor/sender applications)
Using a stock truck temp gauge, but can't bring myself to butcher it up to make it fit something. Does anyone have any idea what I could mount this to so that it's stable and maybe protects the terminals on the back? The intent is to be able to move this between vehicles, so not a permanent fixture. Maybe like a box, thin angle aluminum, something. I'll probably run two gauges as I will probably want to see trans and oil temps both.
The gauge is set up so that the face bolts up at an angle, but that's not really an issue since I would be able to angle the setup however I need to.
Ideally I'd like to make it look halfway decent (had considered using a hole saw and mounting them into a 2x4 lol), but I'm not going to go to the hassle of covering the face of the gauge, etc.
Edit: For future reference, Mouser part numbers for the connector and terminals for the three wire temp sender/sensor:
Three wire connector, with both seals assembled: 829-12065287 (Delphi number is just the portion after the hyphen) ($2.00)
Three wire connector, bare: 829-12065286-B ($.41)
Connector wire seal: 829-12065285-B ($.48)
Terminals: 829-12110236, 829-12089290, 829-12103881 $1.19, .25, .30 respectively
Seal, connector to sensor body: 829-12052893-B (this is a guess, I did not order, but is violet as what assembled connector has) ($.39)
Cannot tell the difference on the terminals, didn't compare closely, but all appear to work with this connector. Probably each for thinner or thicker wire.
