This isn't a pointless post, but it's not likely to have a resolution for months. I'll have a little hands-on time to spend on the truck to hunt this down before I have to use it. I'd really rather not find the cause due to failure while I'm in the woods.
There is a vibration that is felt (and heard) through the whole truck at most vehicle speeds, but pronounced the faster the rig is moving. Only notice it on deceleration. Any amount of throttle seems to "stop" it. It's a very rapid vibration. Happens in or out of gear, but appears to be more pronounced when in gear. Its a bit of a growling sound I'd say. Trans and engine mounts are both new, and both poly. Vibration started well after their replacement.
New (sub-10k miles) L31 crate long block, runs good. Exhaust is fine. Manual trans, new clutch with engine. NP241 with SYE. Rear shaft is in good condition, front is as well. Both regularly greased. 10 bolt front, 14SF rear. Stock 15" wheels, 33" BFG AT KO2's. Don't feel any weird slop in the rear driveline/pinion/CV. Can't recall any impacts or events that could have bent a wheel, damaged an axleshaft, etc.
I'm thinking that best idea is to put it up on jackstands and statically check all four wheels for axle/axleshaft issues. Next, start it and let it run in gear to see if I can replicate the issue on the stands.
I wonder if the front axleshaft u-joints aren't a potential cause. Would that even be noticeable in 2WD with the hubs turned out? The joints are factory original, but last I checked still looked ok externally. Hadn't started to walk out the caps or anything obvious like that. They've got to be bone dry lol. Would an issue with those likely be more easily felt or heard on the jackstands with the wheels turned either direction, wheel spun by hand? (vs. being straight where the joints aren't really doing any work)
14SF is also suspect I suppose, it was fairly abused when I got it, but when I put it in there were no obvious bearing issues.
I did smoke the front wheel bearing grease a number of years back, but replaced the spindle (had gotten hot at some point, but that seems very common from people misadjusting wheel bearings, no idea what the cause was on this one) and re-greased both sides. But the repair and re-grease was a number of years ago, and I've checked the wheel bearings through the wheel push/pull method a few times since then. This vibration definitely did not arise immediately after that "repair".
Any other ideas? Thoughts/better ideas on my process to try and ID the noise?
