bot0611
How can i tell if they are goind bad??
Or change them till they get broken?
Thanks..
I got a damn vibration that im trying to get to.
Thanks again!!!!
We need to know more about the truck, vibrations can come from lots of places.
The truck in your avatar picture looks too new for a full time t-case (NP203) or full time hubs so if the vibration is happening in 2WD its not anything in the front end.
Any chance this vibration is related to your post about the new gears in the rear end?
Your hubs being locked won't cause the front driveshaft to turn, only the front axle shafts. Make sure the transfer case lever is in 2WD HI. If the front driveshaft is still turning, you have a problem with your shift linkage or something. I guess an axleshaft U-joint could cause some vibration if the hubs were locked. You have manual hubs, right?
OK theres a lot of stuff to go through damn..
In 2H hubs locked (manual) the driving felt odd, i had to stop and unlock the hubs and it felt diferent dont know how or why but thats another case. right now im dealing with an intermitent vibe thats annoyind the hell out of me. i have a bad rear yoke, its loose just a bit i hope i fix that and get it over with im eagger to go on the trails again before the hot weather comes in.
