Got everything hooked up and was trying to start this K5 for the first time in 2 years. Once I had the positive battery side connected I could hear the "door open" buzzer. Sure enough, the door was open, so I shut it and the buzzer went off. I thought Great, now if only it will fire up.
Nope.....it would click at the solenoid. Turn the key and click. No starter, nothing. Just a click. I have the ford solenoid hooked up so I decided to take the solenoid wire and connect it to the actual starter solenoid. And moved the starter cable to the battery. Turned the key and snap. Now I don't have power to the ignition. No door buzzer.....nothing. I checked the fuse on the firewall and still have continuity there. Checked the fuses by the parking brake and all are good.
Any other fuses or inline fuse I'm missing?
