Jessie James
I just swapped in new injectors into my 1990 350, along with a new fuel pressure regulator & spring, new o-rings, a new fuel filter, new cap & rotor, new plugs & wires, and a new battery. Now when I try to start it, I turn on the key, hear the fuel pump charge, it turns over fast and smooth, and will start with starting fluid. However, it dies after a few seconds.
I checked for vacuum leaks and found one line loose on the ball-shaped reservoir near the drivers side firewall so I pushed that back on, and checked all other lines and everything seems to be in order. I've checked all wires that I can see to the various modules on top of the block, and they all look fine.
I've been driving it just fine prior to this.
Any suggestions on what to pull apart and check? I am thinking the fuel pump may not be delivering enough fuel through the new regulator, but I'd like to know if there is anything else simple/obvious I can check before I start pulling the fuel lines off.
jk
