Could do a compression test of that cylinder to verify that the valves are seating properly.
Yep, rtv works well if done rightIf your heads, and block have not been decked you can use the rubber gaskets. If any machining has been done you are better off using rtv.
Be fore you condemn the rtv double check the oil sender and distributor, also the valve cover gaskets. I fact as it is a new build you should double check every thing. Oil pan rear main oil galley plugs, any oil cooler connections .......
