handloader90
Building!
Bout to finish my truck up and I was going to order a steering stab.
I swapped falt top knuckles onto a D44 that didn't originally have flat tops. My knuckles are reamed from the top vs. from the bottom like the knuckles original to the axle.
My tie rod is sitting above the axle tube.
I've got another flat top knuckled D44 in my garage and the axle side steering stab mount is in a totally different spot than the a le that under my truck.
I'm running crossover with a HD tie rod and bend draglink.
I was planning on doing hydro assist down the road.
I think i should be fine without the stabalizer but figured I'd ask first.
