If you use the fel pro I linked just rtv in corners block side, basically the seem for rear main cap and the tin to block at timing cover. If you have 4 piece set Gasgasinch for the long areas and same rtv in corners. Make sure pan and timing cover flanges are flat and bolt holes are not coned shaped
