knottyrich
yup yup, right on man. i have a bad problem with making things more difficult than they are! i get all worked up and worried i'm doing somthing wrong. i 'ppreicate the help guys.
Snug the outer one?you torque the inner nut to 50ftlbs and then back it off a quarter turn. Slide the lock ring in and make sure the pin on the inner nut finds a hole. Then snug the outer on.
The torque spec is like 180 for the outer nut. If this starts to move you'll trash the bearings, spindle, etc....Snug the outer one?The torque spec is like 180 for the outer nut. If this starts to move you'll trash the bearings, spindle, etc....
German torque specs....... Guud-en-tightI usually put about.... All I've got into it
