I need a hydro boost set-up to convert my brake system to make it work better. I'd like the master cylinder also but I'll take whatever parts I can get. Thank you!
V belt is sold!The serpentine set up is what I would want. Your set up has master cylinder, hydro boost, PS pump, lines, pedals, prop valve? 75 for all of it? How bout some pics. Please get a shipping quote to 32216. Thank you!
No brake lines to,or prope valve. All else you mention is there (shaft off HB to brake pedal?) and all I have left is the serpentine belt one which has a separate pump and hose to resovior. And I don't know why but the pulley is off, I must have taken it off for something? Been on shelf high and dry for 5 years.So you have MC, hydro boost, prop valve and PS pump and lines? Does the set up come with the correct shaft? How much do u want for it all? What's your zip? I'll assume 100# worth of stuff and find a good rate and let u know.
