ISO; hydro boost brake system set up
firemedicsafd
Professional Murphy magnet
St Augustine, Florida
I need a hydro boost set-up to convert my brake system to make it work better. I'd like the master cylinder also but I'll take whatever parts I can get. Thank you!
Hydroboost system
I will have everything you need soon! Probably a couple of weeks before I have everything removed! Hydroboost, master cylinder, pedal assembly, prop valve etc.
Shipping would be killer, it's all heavy. I have a complete setup for V belt and another complete setup for serpentine belt.
$75 each plus shipping!
The serpentine set up is what I would want. Your set up has master cylinder, hydro boost, PS pump, lines, pedals, prop valve? 75 for all of it? How bout some pics. Please get a shipping quote to 32216. Thank you!
fyi I swaped serp belt on my 79 years ago . the 79 pump bolted right on the bracket minus the American thread bolts I had to use over the serp belt bolts for p/s pump being metric .
super easy swap .
V belt is sold!
Serp belt system still here.
No pedals! In all the IH vehicles I've put these in pedals were not needed but correcting length of shaft was.
Everything else is there and I had drove both these one tone chevys before they were parted.
Shipping? Who knows and I'm not carrying it back and forth to Fed Ex. It's been a long time since I shipped heavy boxs and they were always cheapest. Like $50 for an IH four barrel intake which is heavier IIRC?
Guy that bought the V belt gave me $100 for shipping and when I ship it and get a price will refund him what's do.
So you have MC, hydro boost, prop valve and PS pump and lines? Does the set up come with the correct shaft? How much do u want for it all? What's your zip? I'll assume 100# worth of stuff and find a good rate and let u know.
No brake lines to,or prope valve. All else you mention is there (shaft off HB to brake pedal?) and all I have left is the serpentine belt one which has a separate pump and hose to resovior. And I don't know why but the pulley is off, I must have taken it off for something? Been on shelf high and dry for 5 years.
Fit in a banana box which is HD, weight 42lbs cost to Oriville Ca was only $38.30
My zip is 83815
UPS was 67 ground.
FEDEX was 55 ground. Who did you use when u shipped to Ca?
How much did you want for your set-up?
Message intended for eaglemark
I always use Fed Ex for big and heavy boxs, they've always been lowest price!
Idaho to FL is a long way compared to Idaho TO CA...
$75 plus the shipping for the only one I have left which is Sepentine. But the pully was removed and in box and I for get why I removed it? I pulled the system from driving truck and had a project for it that never happened. Been sitting high and dry in shop for five years. There is no brake lines on proportional valve. Rod to brake pedal is there.
