It's done!!!!!!!!!!!!/ got my dana 60!!!! long
Re: Got my Dana 60!!!!!! LONG
That's probally what I'll end up doing I really wanted true duals with a crossover pipe do you think I could mount the O2 sensor in the crossover pipe ?????? /forums/images/graemlins/truck.gif
No, most likely the oxygen sensor will not work in the crossover. It needs to be located close to the manifold/header to work properly, unless its the 3-wire heated version. The one-wire sensor, most likely what you have, needs a certain amount of heat to work properly.
Just my .02,
John
What about putting it in just one header collector I k /forums/images/graemlins/truck.gifnow it would only Read from that bank of cylinders but it shouldn't affect any thing unless I have a problem with a cylinder in the other bank right??????
Most O2 sensors are only on one side of the exhaust. Both my 89 and 90 K5's have it in the driver side exhaust manifold. You will be fine doing it in just one side or the other.
Thanks I didn't look at were the 02 sensor was but I dont remember it being in the Manifold I thuoght it was in the y-pipe have to call gramps to see Thanks for the help guys /forums/images/graemlins/grin.gif /forums/images/graemlins/truck.gif
okay called gramps the 02 is in the manifold so i'm thinking I can weld a bung into my new header collector And install it there what do you guys think???? any problems I may run into ?????I plan on desmogging this thing as much as possible In the intrest of mileage and power This truck is gonna be my daily driver / tow rig / general 4-wheeling vehicle i'd like to put a powerdyne super charger on it and maybe some other upgrades Any ideas the truck has 4.10 gears and 315-70-16 bfg/MT's on it /forums/images/graemlins/truck.gif
Yes, put the sensor in the header collector. That should work fine. Some were in the Y-pipe, some in the manifold down pipe, but as long as it near the cylinders, it should work fine.
John
Cool that's what i'll do then You guys got any other tricks to get more Power/mileage out of these TBI bigblocks ????? /forums/images/graemlins/truck.gif
Well I got my new headers yesterday and welded the O2 sensor bung into the collector And then I built some tempory pipes that will go just past the cab with 12 inch glass packs (used my yellow truck for the measurements ) this weekend I'll get the trans/t-case in it and drive it home pulling the stepside on the trailer And then next week I'll have the 3-inch pipes with my new 2- chamber 40series flow masters CAN'T WAIT /forums/images/graemlins/truck.gif
Well guys I'm leavin' to work on the "New" truck If all goes well I should be drivin it home this Sunday I have every thing I need Incuding new U-joints I also decided to put my old 4" rancho lift of my K10 on it if I have time /forums/images/graemlins/thumb.gif man I'm so excited it's better than Christmas morning I still have to go get the trailer from the house already have it loaded using the K10 to pull the trailer over there (Hope the t-case holds up /forums/images/graemlins/crazy.gif) Pullin' a trailer with a short bed on 8" lift and 37" tires should prove to be a challenge at least the trailers not loaded to heavy (Trans,t-case,lift ,and pipes ) I had to borrow a 8" drop hitch to make the trailer sit level /forums/images/graemlins/eek.gifbut if every thing works out I'll be pullin' the stepside on the trailer home /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gifWish me luck guys /forums/images/graemlins/truck.gif
WOOOOOHOOOOOOO!!!!!!! got it done man is this thing awesome I love this truck it pulls like a monster that 5-speed kick a$$ I got 12 mpg pulling the k20 on the car trailer running about 65-70 with a couple of really big mountain passes to run up This thing runs great and rides pretty good for having rancho springs It looks pretty good to I'm gonna take it down this afternoon and have the exhaust ran and this weekend I'll puy the stereo in and a new crossbed toolbox (diamond plate) and a head ache rack also I need to register it today (using the yellow K-20's tag and registration ) it's so nice to hvae something that's not completely wore out even the cruise contorl works /forums/images/graemlins/thumb.gif it's a good thing it's done cuz the K-10 was sounding like a box of rocks when I got to gramps house Don't think it'd make the trip back home but now I can tear it down and put the Np205 in it I'm gonna take the "new" truck and cruise this weekend Maybe race a couple of "ricers" /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif Can't wait to drive it again /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/truck.gif
