Am I blind or does the way you're tying your sliders into the crossmember make it impossible to drop thus making the transfer case/tranny impossible to drop from the bottom?
transfer case can unbolt and come out without removing anything. The trans crossmember itself, it still removable by being bolted to the factory trans crossmember holes on the frame. I've got to add some interlocking tubing connectors later. Haven’t purchased them yet, but it’s pretty simple to add those later. The front tie in will have to be independent of the trans crossmember and what I’m figuring out how I want to do today after I do the both rear tie ins.
