MrSchaeferPants
Wanted. If you have also and don't need the air filter housing and studs and wing nuts, I'll take those too.
Shipped to 71956.
Shipped to 71956.
Shipped to 71956.
I guess dual plane if all things are equal? I barely know the difference, other than supposedly dual plane is better for lower rpm.
Either way all I'm looking for is removing the egr mess, and going to one single cdr hose.
Do you have the air box and studs? If not, does the c code airbox and studs fit the same? Either way I need at least new studs, one of mine are mangled and the wing nut stays loose and the top vibrates constantly.
N/A you're better with dual.Weights the same, both aluminum? I'm still trying to research single vs dual. You know some reasoning for the difference? Either way I'm interested in one or the other.
I'll keep reading up.
Well... anyone have one I guess?
Sorry I forgot. ..
I'll get on it
