G
goldwing2000
Guest
When I'm swapping axles (done it three times, now), I use two blocks stacked up (holes vertical, of course), a piece of plywood on top of them and then a jack stand set as low as feasible on top of the plywood. Plywood is better because it doesn't split like solid wood and the feet of the stands sink into the first ply to keep it from moving around.
For placement, I support it directly in front of the forward spring bracket on the rear axle and just behind the shackle on the front axle.
Rock solid, even when torquing the spring u-bolts.
Hey guys...I'm back if anyone cares...looks like ya'll have found another noob to play with...rofl...play nice...
