Found all the info from junkyard Blazer.
On the front of the door halfway between the hinges, there are three dimples. The center is for the 1.5" main feed hole, cut with 1.5" hole saw. The two outboard of that are for the 3/16" rivets.
Just under the dashboard are likewise dimples, they are about and inch below the dash and about 3.5-4" in from the weatherstrip lip. These again are for the 1.5" wire feed grommet. The upper cutout/notch in the vinyl kickpanel will align with this hole.
Lastly are the door jamb/cowl modifications with the center hole being an oval, 1.25" wide, 2" tall. Halfway between the door hinges are four dimples in alignment. The two outer are for the 3/16 rivets. The two inner provide you the centers for a 1.25" hole saw. Once done with the holesaw, you will have a relative "8". Simply cut the verical line tangent to the major hole diameter and dress leaving a nice oval.
