I'm pretty sure that's what we used, but it was nearly 20 years ago.Stanadyne makes a diesel specific additive
The weakest link in the 6.2 is the crank. Make sure you check the harmonic balancer for wear and degrading rubber. Mine looked fine but being almost 30yrs old I just replaced it. I used a Delco but am already wishing I went with a Fluid-damper.
The starter relay under the dash is also prone to failure and hanging. Google “doghead relay mod” for the instruction over on Steelsoldiers. Steelsoldiers.com is an amazing resource for these old heaps.
The cartridge fuel filter is also problematic. I’m about to swap mine for a spin on version.
As you probably know the electrical system is a bastardized 24/12v combo. Some like to convert to 12v only but that will require a new starter and some rewiring.
Should work on that truckA little TIG practice. Don't laugh too hard I'm just starting. Have the 35's ready to go with wheels. (K5 left over) Lift kit ready and will be starting on install next weekend if time permits. Will the 2.5 flip kit from the K5 work on this truck or no?
I do not believe it will. Leaf spring spacing is different.
This.I do not believe it will. Leaf spring spacing is different.
It's not length but the spacing side to side. I believe 1 ton frames have narrower shackle mounts. ORD shows a different part # for 1 tons.Correct me if I'm wrong here but I thought the ORD kits could be used on the 56" rear springs if the shackle flip brackets are swapped side to side.
Gotcha. Wasn't sure.It's not length but the spacing side to side. I believe 1 ton frames have narrower shackle mounts. ORD shows a different part # for 1 tons.
