Different setup. I have a stock HEI coil and some other parts from my HEI in my tool box though.
This is the replacement for my dizzy. Look the same or at least does it have your application listed? http://www.summitracing.com/parts/msd-8225
I'm not sure. We were thinking about going and staying at browns valley with family thursday but I'm not sure if that would be worth the drive. Which way do you think would be fastest? I think it will be my girlfriend and I, no dogs with us. We will also have a friend coming with his toyota that has been through the trail 3 times... Its on 33s!
I wonder if you can do something temporary for the trail. Like duct tape some angle on the panel pinch weld area lol
I think I'll just chance my current coil and hope Skunked's coil fits if needed. I'd like to try a different dizzy, maybe a Mallory, so spending ~$90 in spare parts for the MSD doesn't sound appealing.
start getting the bubbles out of the hydro setup
Fill the system, jack the wheels up off the ground, unlock the wheel and leave the engine off, saw the steering wheel lock to lock maybe 1,000 times. Watch the reservoir and fill as needed. The most I have in the tank is about 1/2-5/8 full with the wheel to one side, anymore than that and it just spills out. Once it stops going down, start the engine and continue sawing the steering lock to lock.
Worked for me![]()
Worked for me![]()
Just to add to this, here's what I did, and I had my system bled in less than 15 minutes:
Hook everything up except for hydraulic line which is connected to the cylinder, but not to the steering box. Jack the front of the truck up so both wheels are off the ground, and push the wheels fully locked to one side so that the ram is completely collapsed on the side with the free-hanging hydraulic line. Then, using a funnel, pour fluid into the line while a helper VERY SLOWLY turns the wheels back the other direction. When you get to full lock on the other side, then you'll know that half of the ram is completely full, and the other side has as little air in it as possible. Then connect your line, fill your reservoir, and do the normal process. Might even be able to do this even better if you were to connect the line, disconnect the other and fill it up the same way before moving on to the reservoir.
Also: To those concerned about your rockers:
If you're careful, you can do the whole Rubicon trail (bypassing old sluice) without sliders. I valued having mine, but they're not absolutely necessary. I don't know the specs on all your trucks, but if you at least have the "standard CK5 mods," I think you'll do just fine.
Gold!! thanks for the run down. I've read your hydro thread 1.5 million times, definitely has helped. So ill pitch the wheels to one side and fill up the non collapsed side of the ram. I wont have a helper but I think I can manage.
Great to hear this. I was really getting worried. a few scrapes and bumps are fine but id be heated if I couldnt get my door open without a sawzall.
I have 40" tires and about 5 inches or so in lift so ive got good ground clearance...
No, you begin filling the collapsed side as you open it - thereby sucking the fluid down into the ram. If you try to fill the non-collapsed side, it won't work. You need to use the vacuum to your advantage.
I doubt you'll have any problems with clearance then. So I'd say you should really focus on steering, because with tires that big, your hydro will help a lot in those rocks.
And one final point: When you camp at Buck Island Lake, make sure to take some time to swim over and see the waterfall on the SE corner, then hike up the river to the other lake. You'll be glad you did. It's gorgeous.
is that Rubicon Springs campground area? Do you have to swim? Just considering equipment needed![]()
anyone else planning on fishing?
We figured we'll have some time at Loon and Buck to fish![]()
Ill probably bring swim trunks but doubt ill use them. leave the ck5 speedos at home!
I'm thinking the water is going to be too cold still
