Hi all, I just picked up a 1980 Blazer from an old guy who had it sitting for the last 4 years. Completely stock, except for a recently replaced sbc 350 pulled from who knows what, with an edelbrock manifold and "rv cam." Car seems to run and drive okay, engine needs some tuning.
Questions are:
Water temp gauge shows 3/4 at operating temp, while my infrared thermometer shows 190 at the thermostat neck and everything seems cool in the engine bay. I can put my hand on the radiator cap no problem. What should I mess with first, the sender or the gauge?
Dash is cracked up pretty good, if you see the photos. Do you think this can be salvaged with one of those plastic glue on covers? Or should I look for new dash?
There's some weird skid plate underneath the front axle, is this Factory? I doubt it's strong enough as a jacking point, where should I jack up the front of this thing?
thanks guys!
Cracked dash and temp gauge 3/4
Front axle with weird bash guard?
And the car itself
Questions are:
thanks guys!
And the car itself
