If you know Holley carbs then I suggest going Holley. I definately make way more power with my holley than I could with a q-bog. I think they are the way to go.
LOL! I know what your saying but i cant help it, its in my blood! Hell i already ordered, ceramic coated long tubes, holley blue electric fuel pump, manual block off, new seats, new steering wheel, new oversized radiator, flexalite electric fan, all new guages. Still deciding on the carb, lift and tires.. I have decided, not to go over about 6" inches lift and 37" tires till later on and i get 1 ton axles..
Whatever carb you go with will need some basic tuning or adjustments to get it just right for your engines needs. You should find someone in your local area with carb experience. It's hard to try and tune it over the net, really has to be done in person.
If your going to go thru all the trouble with a holley blue and reg. you might as will go all the way and get the Edelbrock manifold RPM and holley Double pumper. I would go 750cfm just incase you want to do a cam swap or bigger motor in the future.
Thanks thats what i been hearing! Manual or electric choke?
you can lead a horse to water...
I've been working on Holleys for 30 yrs, and contrary to what you want to believe, for a stock to moderately modded motor, they can't touch a quad...
But "most" of the guys on here appear to be running holleys...
