This morning before I had to go I got the new longer u-bolts put on the front, greased everything and put some tiny bungie cords on to keep the front brake lines pulled away from the tires.
This evening when I got home I was pretty beat but knew I had to get at least one thing done so I whipped up the winch setup. Pretty simple and straight forward but I think it'll work perfect.
Welded on some seamless receiver tubing with a little gusset underneath it. I mocked it up and then pulled it off to weld the gusset to the underside of the receiver tube so I was sure I got a good weld on the bench then set it on and burned it all into the trailer tubing.
Then used some 2" x 2" x .250" wall tubing and just capped one end and drilled the hole for the pin and the two holes for the winch then ran some 5/16" grade 8 bolts through the base plate of the winch through the tubing.
Everything stores away nice and neat in the toolbox on the trailer...
Tomorrow is kinda busy too so I'm not sure what I'll get done. I should have some time in the evening to maybe mess around with the floor then get it loaded on the trailer.
Definately worth it though for piece of mind.
