Don't even mess with carbs! The install was really easy and I couldn't be happier.
thanks again for the advice
That was not the answer I wanted. I wanted cheaper is better!
You live in California. Find a TBI rig that failed smog, cut it up, haul the balance to iron.
Martin
Did you go with a baffled fuel tank/cell or just run what you had?
So have you done anything else or is this build officially complete now?
Enjoy your trips and keep us posted!I can't remember, what rear springs are you using and how are they holding up / are you happy with them?
57" Ford springs out of an early 90's half ton. They're holding up great and flex really well.
I put some vision x rock lights on and stripped a few t-case to trans adapter bolts.
I'm going to get it through a snow trip in a couple weeks and a dune trip for new years then I'll tear the doubler out and fix it permanent.
I'm also working on some softer springs up front.
