80' 427 submitted a new Build:
K30 with a 6.2
Read more about this build here...
K30 with a 6.2
View attachment 230756 I have posted in the Garage section but I was thinking this may make a better place for my stupid questions about my 1982 K30 with a 6.2.
Here are todays
I has a new pump and runs pretty good. Should it smoke? I mean it doesn't smoke at all but I haven't put alot of load on it but accelerating it doesn't ever smoke.
The previous owner put on a puroilator fuel pump in right after the tank switch and unhooked the mech pump. Is there a reason I can't just run both? More or less use the elect to feed the mech pump? I thought it would help prime the filters and such after a filter change.
...it was completely coated with clay and dirt,plus they used 3/8" rubber fuel line all the way to the Raycor filter on the firewall,which I'm sure dont help any..........................................................far as I know the stock mechanical lift pump isn't hooked up any more...that truck often is a bitch to get started,and I'm not so sure its the glow plugs,because it seems to want to fire up right away,but unless you keep it floored and let it race a good 10 seconds,,it acts like it ran out of fuel--leaving the key "on" and waiting a minute or two seems to let fuel build back up in the filter,then it'll finally start most of the time...I usually need to jump the half dead batteries by then though....that 6.2 might be tired though,or need injectors,it smokes some out of the drivers side bank....
