K30 with a 6.2
You take them back off? The pics from back in '13 looked good
If the block or something in the 6.5 isnt good i have another you can have almost free. it ran fine when i pulled it out, but im about 87% sure it only has 7 pistons still rotating. Still had good oil pressure though.
Just seen a factory tack cluster for 150.oo in my local classifieds, looked good but I got one and thought that was a bit high? May be not?
I paid 180 shipped. It was more than I usually would give but I wanted it to match my other gauges. If it all goes well I will likely fix up my 79 cluster for either my crawler or my 84 k10.
So today I tore apart my 6.5 to see just how bad it its. This is the place a starter should be bolted when a guy sells you a engine, saying it comes with "everything" .
the cylinders were pretty clean but it has the small square pre-chamber cups. One cylinder had a little water in it at one point, cylinder is rusted and head shows corrosion.
This is the improved block, not only because of the smaller out bolt but the cap is much wider and is stepped not being the same height all the way across.
Pretty clean inside
No sludge in the bottom, thanks you fleet maintenence
Bearings don't look awesome but not bad. Few groves from dirt and contamination.
This is where you look for cracks, they tend to propagate from the outer bolt hole.
These extra boses are suppose to help you identify the "improved" block
Since we are on the subject, wtf is a precup? I'm assuming it has to do with the indirect injection cuz I never heard about it with my cummins.
It is the small chamber the diesel is injected into that also holds the glow plug. Different sizes give you power or economy. Problem is there is no math only speculation. Look up recardo comet. Mine have the tiny square ones for mpg in a chip truck.
Just getting acquainted with the thread, and I can't get over Martin's perennial response to every early update. :rolleyes: :haha: :thumb:
Pics?
Martin
Pics?
Martin
Of course I am wrong anyway. Did a lot today, since most of it will be wrong I will just keep it to myself.
Pics of all of the stuff you did wrong today?
Martin
Please.
Martin
why, i already know it won't meet the marty standard.
Because you owe me $100.
Martin
I owe someone a 100 but I am not sure it is you.
Yeah. Well I still want pictures.
Martin
Oh, and you want that hood, right?
Martin
Fine
[pics]
Marty we both know you and I are the only ones looking that this tread.
I don't care if anyone else is looking at it or not. I still want to see pics.
Thanks for posting them by the way. Oh, and did you want that hood?
Martin
Pics?
Martin
So . . . . . . . . . . . . . . no pics???
Martin
no pics, not around it. NO nos anymore. We tired to break it once.
Are you around it now?
Martin
I should have taken some pictures.
Martin
Take any pictures?
Martin
Pics?
Martin
I think Martin has a 1-track mind. :rotfl:
Martin must be pretty demanding.. I can just imagine him as a 12 year old in a chat room in 1998.. A/s/l hey baby! Pics now!!! arghh pics! Detroit!!! buzzin dozen!!
