The large 10.4 mm wires are mostly silicone, yes, they do protect better against the spark jumping through the silicone and they do have a resistance probably 1/3 of stock, but with an even lower resistance wire the 10 mm jacket is not needed as the resistance to travel through the wire is smaller so it doesn't want to jump through the silicone. The Taylor Thundervolt are 1/6 the resistance of the 409 and about 1/32 the resistance of stock.
Now if the spark plug gap is too high then it could still cause issues as it has to jump the gap even at higher pressure.
Larry, I don't recommend doing that to your engine. Lugging the engine at 800 RPM the ECU has to have your timing very low at high load at near idle RPMs using the higher gear. It's a spark ignition engine not a compression ignition engine, its not that efficient there and you would likely save fuel and potentially parts by going down a gear and holding it at a still relatively low 1200-1500 RPM. I know it will do it, but as you are seeing it wasn't designed to be driven that way and high load at very low RPM on an NA gas motor is not good for it. It's the best way to get detonation because the piston is going down very slowly, but the combustion still happens fast. And at higher load, it's a big fast bang on a piston that's moving very slow, that's almost detonation even if its not detonation yet. Cylinder pressure is apparently spiking very high or it wouldn't be causing spark to drop out. I know the 8100 is like a tank and it can take a lot of abuse, but it will last even longer without it. In my opinion lugging the engine at high load at 800 RPM is much harder on it then running it at near redline at any load. Now diesel fuel burns at a slower rate so that's easier to do, especially when you add boost because if you record cylinder pressure during combustion boost gives a longer push rather than a fast bang.
Remember, a 1/4 throttle at 800 RPM is basically floored as far as the engine sees, it probably can't take in any more air at that RPM than you are already giving it. The higher RPM can pull more air. Even at 100% volumetric efficiency (which is is probably not achieving) at 5500 RPM it would want to pull in about 790 CFM. But at only 800 RPM it only needs 115 cfm, which it can likely get at 1/4 throttle.
Sorry my distributor didn't have those in stock Wes, thanks for checking with me, I appreciate it.
