- Joined
- Jul 18, 2000
- Posts
- 1,695
- Reaction score
- 2,115
Larry,
I have some questions on what you are doing to remove and install the engines.
the manual says to attach J36857 to the heads using 9428217 and 15650963.
Do you have an alternate method that might be more easy to procure?
Thanks![]()
I just lift them like any other old big block by bolting a chain to the heads. If you have any of the old lifting brackets that used to come on older SBC and BBC I would suspect they would work fine as well. I didn’t have any of those around. The tool numbers you posted are designed to help stab these engines into the GMT800 trucks where the engine fits deep under the firewall. If I recall those brackets also require the intake to be removed. They would be nice to have but not necessary for install into an older rig.
I didn’t use the orange equalizer bar on the burb (and actually haven't used that dumb bar in years). That bar used on the K10 tends to beat up the firewall while you’re trying to stab the engine. Don’t let the upside down hook in the picture at the front confuse you. The chain is bolted to the head with a large washer. The hook is just laying there
