I have a couple question regarding this swap. On the MAF sensor if you decide to swap over to the L29 throttle body. First of all, where is the MAF located on the stock L18? On most of the LS based motors they are right next to the throttle body. So just thinking about it if you swap to a different throttle body to keep mech throttle, how does this affect the MAF sensor? I saw Larry's post on the first page that shows his aftermarket air intake set up that looks like he adapted the stock MAF sensor into this, but what is everyone doing if you are swapping to the L29 throttle body?
Also, what is the final consensus on the VSS? I know it was discussed a couple pages back, but are you saying the L18 pcm does not need any type of VSS/speed signal to run correctly? Just seems weird to me, but that could be because I know with TBI it's almost necessary (as I just did a TBI swap in my K5 not too long ago). Anymore input from you guys on this would be great.
Lastly, has there been anyone who has successfully set up dual sattle tanks to work with this now? I saw the discussion about not being able to find the correct size return line, but has anyone found a good success to simply have the dual tanks work well with this?
I just purchased a 1989 v3500 crew cab with a TBI 350 in it that I want to swap an 8.1 liter into. It would be freaking sick!!!
