L18 8.1L swap resource thread
She is in her final resting place before major surgery of being a parts doner . Quick rinse under hood got 5lbs of dirt out and she is clean and all there .
last pic is the 3 here and running . i have 1 parts truck ready for scrap / 1 94 waiting for this ones 8.1/4L80-e and 1 running 02 8.1 / 4L80-e not sure yet maybe in to new plow truck build .
Another one on the hook today . This one is at my friends storage lot . Its got 211,xxx miles runs good body shot and frame shot . Another good parts doner tho . Already ownend it just had to pick it up today .
Up to 4 c3500hd/ 2005 2500hd / 02 motor with spun rod bearing but run good . I think i have an addiction problem .
I am even thinking swap my 2wd c10 from the 5.3 to one of these
I am slowly getting that 8.1 out of the van. To much life getting in the way of shop time.
Few question, any one use the factory instrument tach, if so what did you use for the signal.
I have ordered a throttle cable throttle valve off ebay, GM17096144, and am looking at https://www.summitracing.com/part/trans-dapt-performance-products/2566/853047#instructions for the spacer, is this the correct spacer?
Spacer for the 7.4L throttle body? I used the one linked below however it’s showing as discontinued.
You’re talking the wiring for the squarebody gauge but tach signal from the 8.1?
Are you bringing over a newer transmission with the 8.1 and just need to make an old cluster work, or are you using old transmission and cluster and need to double adapt?
yeah I want to keep my factory gauges esp the tach. since no HEI to signal the tach I am hoping the ecu has a suitable source.
yeah going to up grade to the 4l80e, I believe i'll need to have the electronic t case output signal. Speedo is not that important, I could use a gps driven motor to work my factory gauge or just get a gps speedo. I do like my tach.
So who has put a np205 behind a 4l80e ? did it need any clocking how is the front drive shaft clearance ?
Gm did factory 1 year 4L80 & 205 . Also 90-91 electric speedo .
My Howell harness came with a lead labeled tach signal. You have to run a special resistor, but then you use that as your signal and run the rest of the squarebody wiring. I can see what pin it uses for the signal if you want.
When I had my ECM reprogrammed, LT1swap.com set the ECM to read as 8 cylinder so it would make the tach read correctly.
I remember they said it could be changed to whatever you wanted.
