A few months ago I installed ORD cross-over steering and tie rod with a new 2-wheel drive steering box on my 91 V3500, and a set of new 36/13.50/16 tires. The steering gear box is an older 3/4" splined shaft type. These new tires and parts are causing a massive amount of steering play that my truck did not have before.
After some research I am pretty sure it is the original stock steering column intermediate shaft my truck still has causing the problem. I have looked at the Jeep XJ shaft modification, but since I have an older 3/4" splined shaft steering box, I do not think that will work. I have looked into a Borgeson intermediate shaft PN# 000935. This should fit both ends of my column and steering box. This part is somewhat expensive, but I think it is the only solution I got. Any thoughts are input on this.
