Yeah definitely revisit the alignment. Caster has a decent range but if it's out it can cause a number of issues, most commonly seen is death wobble but that can usually be attributed to caster plus worn parts. Caster can cause wandering and a lazy return to center.
As far as adjustment, you can do thru leaf spring shims and even offset lower bearing pin plates. I brought mine into spec by slightly changing the length of my front spring rear shackle.
