CrpMag122
I will second that. I am curious as to whether it will fix your issues.Let us know how the install goes.
20 seconds under the truck with someone else steering will tell you where 90% of the slop is coming from.
you need to put it on the ground and have somebody turn the wheel back and forth as you watch every steering part.
is there two different early boxes?
I got another steering box with the 30-spline input, and test fitted the Chevy Express van steering shaft. It fit...no problem. I wonder why people buy the XJ jeep shaft because of all the hassle with heating up the shaft, in order to melt down the plastic clip retainers. With the Chevy Express Van steering shaft you do not have to mess with any of that. It is going to take a little while for me to get all that stuff bolted up.
sweet... glad your ready to go...
I bought my xj shaft all set to go.. I didn't have to heat anything up...
just remove rag joing
grind U into steering column shaft for bolt
stretch shaft and install....
tighten bolt on gearbox side
install bolt/nut and tighten on steering wheel... viola done...
it took me literally 10 minutes... so that is why I did it...![]()
Yeah, something is a miss somewhere. I am running 37" tires with zero issues as far as going straight. The issues I had initially was due to the long soft springs flexing side to side a fair amount while trying to turn the large tires, but nothing when going straight. I don't know how many times you have tried to have everything aligned but I would check it yourself using the jackstand and string method to see what the measurements are.Those tires can certainly be at fault BUT they aren't necessarily big and definitely not guaranteed to drive poorly simply because they're bigger than stock. My Blazer has unbalanced 43's and drives smooth and straight with no wandering.
With all the new parts listed I'd look (again) at the frame, caster, spring bushings, etc.
What type of alignment did they do?
King pin conditions?
