Lift/axle upgrade
I have a 3/4 ton front with 3.73's, a lockrite, the biggest tie rod ORD sells, etc. I just swapped to 1 tons, I'm not ready to sell it yet, but if/when I decide to I'll let you know.
What I did when I swapped to 3/4 ton was just get everything from the spindles out from a 3/4 ton. The only difference in a 1/2 ton 10 bolt and a 3/4 ton 10 bolt is one is 6 lug and the other is 8 lug. Then just get a 14bff. I have a friend that just brought one to the scrapyard.
You can go to Barry's and see if they have a 14 bolt. They just moved from canal rd to somewhere off of menge.
I live in Gulfport, let me know if you need a hand with anything.
Edit: Also with the airsoft BB's to balance, I'm running them and I just put one of these containers in each.
If you're willig to part with that lockrite im in dire need of a front locker.
