DAVY DEW
Registered Member
12 inchs needs alot of mods to be safe stock steering with the raised block s arm and s drag link will after time rip the steering box out a list of some new parts u bolt shocks front shaft lengthen brake lines spring bushings crossover steering trac bar block to lower transfer case rear shaft lengthen rear shocks rear lift springs shackel flip or block w 8in springs bigger tires need more rear gear stronger axles it is very costly to do 12 inchs and bigger tires look at other ways to do it if your on a buget add a leaf cut fenders bushwacker cutout flares or smaller tires just something to think about
nice.
