5280k5
You just had to do it... LOL I think I will go with the above lineout converter for the time being until I can set aside the needed money for a replacement head unit.
Somebody had to, right ?
The line converter should be fine for a basic system. Depending on what amp you will be running it might have output rca connections for adding a sub amp. The only thing I would look for with your sub amp is an external control knob to help adjust the bass level since you won't have any dedicated control through your deck.
