linked one ton escalade (coming back soon)
I did just pick up a bunch of grade 8 bolts to finally bolt the suspension in permanently. The 2 bolts for the double shear steering were $8 each! Lol still a lot cheaper than artecs kit though
Temporary exhaust. Luke and I also got a lot of other stuff done, finished mounting the fuel cell, finish welded all the exocage, France the rear driveshaft carrier bearing crossmember built.
As for the front driveshaft apparently I need to find a 95 and newer 241 with the short front output shaft. Then I can use a regular 32 spline 1410 u joint style yoke.
It wall all get headed wrapped, I can’t imagine it’s going to get any hotter than the turbo kit on the van, and it was in a smaller tighter space. Also I have spare fenders, but most likely the turbo exit will be in the same spot.
Exhaust exiting in front of the front seat on anything but an open air, non road driven, vehicle.
That sounds like a recipe for death or CO poisoning to me... Nice rig all around. But that's seems like a bad idea.
No, it won’t get driven near that much. And as I pointed out this was the only place I could go with exhaust without severely limiting the uptravel.
