or you could get a winch. A traction aid in the rear axle will do wonders as well.
Oh ok, I think I’ll start with just installing one in the back for now and see if I’m happy with that. Thanks for the adviceI have a Suburban and two Blazers with Lockright lockers front and rear and they work great. You do have to watch driving on slick roads they do act different.
I did order a winch, I’m just irritated that I got stuck in that spot and after I got helped out I seen a few newer trucks go right over that dang hole. I was embarrassed I couldn’t make it and had to be pulled by a ATV lol.or you could get a winch. A traction aid in the rear axle will do wonders as well.
That’s exactly my thought. I will be adding a winch for situations I really need it but for a pot hole I want to be able to drive through itI would rather make it through than find my gloves, get out in the mud, pull the line, find an anchor, make the pull and re-spool the line.
You will be happy with the lock right or the spartan.That’s exactly my thought. I will be adding a winch for situations I really need it but for a pot hole I want to be able to drive through it
I hear you, and have traction aids in both axles, and a winch.I would rather make it through than find my gloves, get out in the mud, pull the line, find an anchor, make the pull and re-spool the line.
Awesome thank you so much for this info I really appreciate youYou will be happy with the lock right or the spartan.
Easy to install and very smooth in my experience.
I had it on ice and snow and I wouldn't say it was scary as long as you were driving like you're on ice.
I know some people feel invincible if they have a 4x4 or a locker.
It's just a little edge.
An added benefit but you still need to drive smart
Didn’t hit it fast enough!I did order a winch, I’m just irritated that I got stuck in that spot and after I got helped out I seen a few newer trucks go right over that dang hole. I was embarrassed I couldn’t make it and had to be pulled by a ATV lol.
I tried that and didn’t work lmfaoDidn’t hit it fast enough!
Do you know if the rear end is open now or if it has the G80 Gov-lock? If it came with one, the RPO G80 would be on the glove box sticker, but in a 44-year-old truck you can't count on anything being stock. If it worked, you would have been able to get out of the hole after 1 wheel spun and the differential locked. However, they sometimes break and don't engage anymore. They don't make a drop-in lunchbox locker for that differential.82 k5 blazer
