86-1ton
ok, i need to go now... too much drool on my keyboard...
Shop manual doesn't say anything about 1 time use bolts for these engines. OEM would use cummins bearings. with a cummins part number.
main #6 has the thrust bearing. crank end play spec Min-.004" Max-.017
main TQ 3 step. 1-44ftlb 2-88ftlb 3-130ftlb
rod cap TQ 3 step. 1-26ftlb 2-52ftlb 3-74ftlb
rod to crank side clearance Min- .004" Max-.012"
locktite and retorque all gearcase bolts to 18ftlb and coverbolts are 18ftlb too.
Dude, there are 4 Cummins suppliers within 5 miles of our houses! I have names and phone numbers so we need to check these out first. Rocky Mountain is like 35 miles away across town.
Do Cummins rod and main bolts need to be replaced when you remove them? Also, what were the OEM bearings?
that was probably overhauled at one point and rods changed. factory stock rods don't have engraving marks like your WC 73683. probably why it looks so spick and span though, unless someone ran some ATF through the oil, or other detergent. I dunno. you got the pan off, pull a main and a rod cap. see what the bearings are. OEM or jobber, STD or oversided.....good a time as any to know what your working with.
See now why I'm never concerned about beating the tar out of my engines....size does matter![]()
so i am seriously starting to consider this type of swap, but the $$ thing...
I know i could eventually find a running cummins for cheap, but its all the extras that would put me into the red big time.
What is a good dollar figure for the extras needed to complete a cummins swap into an SM465 equipped truck (that was already a 6.2 if that matters)?
so long as the rings and cylinders are still half ass good. really the P7100 is not usually the first problem on the engine. IMHO throw bearings in it and run it.
if it was reman'd at some point, maybe the doofus who was driving the delivery van or whatever it was in was just hard on the engine. not necissarily a high miler. the main looks ok for sure though.
Did the governor springs arrive yet?
