Jason4x4
Engine mounts & Engine crossmember $500.00
WTF, didn't you just put an ord one in???
but its easy to cut yourself a nice 10 or 100 plate from your stock one.
The ORD mounts use eye bushings. Here's a pic:
The only bad thing is that they transmit more engine vibes to the frame vs a stock mount, which might not be the hot set up for a Cummins swap...
OTOH, it ain't my truck, so I don't see a problem with it![]()
Dood, I'd stick with the 3k governor spring. All 4k will do is blow a bunch of fuel and beat the motor. I don't care who says what, DI's, particularly the pre-common rail jobbies with their lower injection pressure, are hard pressed to effectively burn the fuel that fast. There just isn't enough air motion in the cylinders. Use the Cummins like it was intended - lower speed and higher cylinder pressure. The 6BT has a ton of torque rise, so you don't need the extra 1000 RPM.
Is that motor from a military vehicle?
1. Your better of the install a 4k because it's there if you need it .Why spend the $$ out just to get 300 RPMs over stock ???
2. The engine won't be at 4k all the time so ,the wasted fuel you talk about is crazy .
3. Replacing the Valve springs is a good idea to begain with .
run 'er. I fueled my 24v over 4000rpm many a time. with the Quadzilla Adrenaline 4K tune. racing will put you up there at WOT still. no problems to report. stock damper. you can beat the tar out of these engines and still come out ok. its not a 6.2 that'll break a crank if you show it a big hill and 75psi
but seriously drivability is whats affected foremost with the governor spring kits. they dont make power, just make it much more user friendy. you have to change the springs with a 4k kit, thats more $$$ there. the 3K kit doesn't just give you a few more RPM, it shifts the whole power band. Tons of good info on that dodgeram.org. I've been in there before too. an aftermarket fluid damper will take leaps and bounds of vibration out of the engine. but thats all not nessisary, slam the 3K gsk and driveability goes up 10fold over stock.
BTW brian you have a postal bubble pack on the way. I have a tracking #.
And one more thing, who sells the KDP kit with the cover gasket and front seal? I've been busy all weekend and haven't had time to search the web.
Greg and I popped the cover off last night and found the dowel pin is more than half way out!![]()
What are you runni9ng in your 12V? A 3K kit, or a 4K kit?
I'll get a 13mm pump sometime down the road too. after I stud, port and oring the head. do a cam shaft...........
