handloader90
Building!
I hooked my garden sprinkler up and set it under my truck to get the mud off so I can actually see what the hell is going on down there.
I've heard really good things about the hydro clutch, when I can find a hydro bellhousing that doesn't cost an arm and a leg then I'll probably switch over just to keep my mechanical linkages from falling apart on the trail,
Pretty sure I'm going retro fit before i pull that pig out to change the bellHave you looked up Novak for hydraulic retrofits for a mechanical bellhousing? It's 200 bucks and you don't need the hydro bellhousing...
It's an option that I've looked into. My only issues is that I can't go and pick up replacement parts from the local parts store that I can swap in just in case something breaks.
All I hear are third pedal problems now
anyone use a softer spring from like Ace Hardware or something?
My leg was dead ass hell today from all the stop lights and stop signs lol.
I removed the spring under the dash
Im lucky and my 465 came with a hydro clutch being a 90'. Only mechanical clutch I've driven is on max02's ratbag. Having been born in the 90's i didn't get to grow up with these things... and not nearly enough of them have been saved up here!
If you want your head to hurt, watch the garage during the week for the countless amount of "my auto blew up" threads.
Dammit....Now I have to go back and check.....![]()
Theres a mixture this week. surprisingly a 465 thread too. Some weeks though it seems constant.
on a regular basis....Probably cause there 100 to 1 more of them? That and a manual it's self is stronger but you will fine alot more problems outside the box it's self....Clutch, linkage, flywheel.But your right about how many autos take aon a regular basis....Probably cause there 100 to 1 more of them? That and a manual it's self is stronger but you will fine alot more problems outside the box it's self....Clutch, linkage, flywheel.
