mudboggink5
Its been getting colder, and when i start the truck up in the morning, i have to hold the gas pedal down just to get it started. When it starts its at a very low idle, and takes 30 min just to get the heat goin.
If i try to drive it cold it will pop,and try to stall out.
Ive recently changed plugs, rotor, cap, o2 sensor, and the coolant temp. sensor. I have off tomorrow, so im gonna check the other sensors, egr valve, tps, and iac. also gonna change the thermostat. any other tips.
Also did the seafoam in the tank, and through the vaccuum hose.
When i took the vaccuum line off the master to do the seafoam, it idled alot better.
Timing to advanced. It is definitly running rich.
