Jessie James
The shop manual says:
Did you disconnect the vacuum line from the distributor (if equipped) when you timed it?
Sounds to me you should put the timing back to the factory spec and take it from there.
The other thing that may be an issue is knock. If you have advanced the timing, when the ECM advances the timing more, then knock may occur, and in that case the ECM will retard the timing to prevent engine damage. That will also reduce efficiency and performance.
So if you have advanced the timing, the ECM doesn't know that and is possibly causing your backfiring.On engines with TBI, spark timing changes are determined electronically by the ECM which monitors information from various engine sensors, computes the desired spark timing, and signals the distributor
The timing was so far advanced it was off the teeth/timing bracket. Talk about a MPG improvement
