I have an LS 6.0 that just threw a couple of codes at me. Looks like I'm lean on both banks. Any ideas on where to start to solve the problem?
lol, I'll save that for plan B.Put a wicked low compression 400 small block in and give no more $hits
Jk. I'm guessing bens idea is correct.
Everything is stock (although stuffed into my '72). Nothing is new. An intake leak or crack seems like the likely culprit.Intake leak, intake crack, FPR kapoot, FP kapoot. Verify FP and post up idle KPA. If you are stock and over 40 kpa then some type of leak or loaded engine.
What manifolds/headers? Is it something new? What is fuel trim at idle and cruise?
FPR, FP, KPA?? What is that?![]()
I'm running hydroboost, but that's another vote for vacuum leak.I had a 02 Silverado do the same, ran alright for saying it was that lean. Ended up being a leaky brake booster. Just a different angle to look from
Thanks.FPR - Fuel pressure regulator
FP - Fuel Pump
KPA - Vacuum
Hook up a scanner, warm up engine and get live data going. Look at KPA and fuel trims at idle. If KPA and trims are high odds are its vacuum leak. If just trims then check fuel pressure.
I'll check it and see what I get.
If you pull the intake might do the knock sensor too, seems like they were problematic. Josh could confirm...
Ok, I let it idle for a bit while looking at my torque app (only scanner I have). I don't know what high values are but I did watch the fuel trim on both banks. It varied between 0.0 and -3.9 for the most part.
I couldn't find a vacuum reading on the app.
That said, after a bit the MIL went off. I cleared the codes and will see if they come back.
