LS Motor Lifting Eye from Motobilt
MotoBilt
Registered Member
Vendor
Dothan, AL
LS MOTOR LIFTING EYE
Motobilt designed the LS motor lifting eye set to fill a need. The LS engine un like most does not have a facotry mounted lifting point. Also the Motobilt LS lifting eye set is bent in so that when pulling or installing the engine it will clear the firewall. These little features make all the difference when working on your rig.
The lifgting eye kit is sold as a pair and they ship raw steel. The gussets come welded already so you can just bolt them up to your engine out of the box.
