Wooden bucks is how a lot of old cars were made.
. Convenience fee I guess.O think that I have scrapped a couple of gmt400 suburban and a couple of trucks that had zero rust, one of the suburbans even had perfect paint, I just had no use for them.Got it done... Then cleco'd it to the outside to get reference holes. Moved it to the inside using those reference holes.
Traced along the top.
Then got it all cut out, and welded back in.
Forgot to get pics of that process/progress though.
View attachment 522107View attachment 522105View attachment 522106
Still have some pin holes to weld up. Then I'll coat this part in primer and start on the outer stuff.
When this all gets done I'll move forward on this side and do under the front door.
I REALLY hope I don't have to do as much on the driver's side.
I would put a wet rag on the hoses close to the welding and I would keep the fuel cap open with a shopvac running and sucking the fumes awayFound out that I'm going back to a semi normal schedule later this week.
So soon I'll be able to put multiple hrs at a time on it
The week after this one about to start, I'll have multiple days I can put LONG hrs in .
Now..... Big question.
How exactly would you go about welding/cutting/grinding around the gas door? Given the tank vents through it .
Should I even worry about it?
I'll be cutting and welding on the red line.
I thought, if nothing else, wet a hand towel and wrap-stuff it around the filler neck, shut the door, and tape the seem.....?View attachment 522563
